265 Stage 2 Tune - Oil Cooler Needed
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by DV8, Jul 24, 2019.
  1. DV8
    DV8
    Hi Guys, I've had a Stage 2 tune (317bhp & 350lbft) and am curious if I need an oil cooler for track time or if I can get away with just the standard cooling and not staying out too long.
    Anyone done Stage 2 and checked out their oil temps on track or gone out without an oil cooler without any problems?
    I would just fit one if i had more time but i'm going next week.
    Mods are Wagner Intercooler & GT Perf exhaust.
  2. I have 361HP (235kW/450Nm at the wheels), no oil cooler and have done 20 minute sessions in 35 degrees on multiple occasions. The R-Link shows water and oil temps the same as OEM.
    DV8 likes this.
  3. There will be mixed opinions on this one
    From what we experienced at Oulton a couple of weeks ago I would say that you need improved water and oil cooling
    Its been suggested that we may need to replace the water radiator. There only appears to be Forge that make an 'upgraded' version
    Maybe just taking the water / oil heat exchanger out of circuit would help
    Let us know how you proceed
  4. DV8
    DV8
    Good to know, thanks. I sadly don't have R-link so am messing about with a Bluetooth ODB dongle and iOS app to see if I can get that working for Oil Temp
  5. DV8
    DV8
    Is yours a pre-facelift or facelift model? I get the impression that the facelift is better at cooling thanks to the design of the front bumper.
    I've been to the track before without the stage 2 tune with no issues but we shall see...
    From what I've read the Forge radiator is actually worse than OEM but I have no experience of this....
  6. Doook hammers that car tim!if he don’t need one, then you should be ok!
    DOOOOK likes this.
  7. Can you link me to any threads on the Forge, their write up suggests it much more effective than oem
  8. I'm not sure - pre facelift ?
  9. Even so the R-Link shows a calculated oil temp, not actual. The water temp is actually measured.
    What also helps with temps is not running a lean tune just to try to get a few more ponies. A richer tune keeps everything a little cooler and a little safer. Other things I've done to manage temps is choosing a Wagner I/C over others that block the whole radiator, ceramic coated the dump pipe and run a separate turbo water cooler (Airtec unit for a Clio IV).
  10. he has a wagner fitted;
  11. DV8
    DV8
    I did a quick search but i cant find it now, came across it while researching Intercoolers - if people have installed it recently and rate it then ignore what i said. :wink:
  12. DV8
    DV8
    It's def richer, i can taste it.. LOL
    Yeah also went for the wagner for those exact reasons. My tuner was pretty impressed with its performance (although not as good as the much bigger Pro Alloy).
    Do you have any pics of where you've fitted the Airtec Turbo Water Cooler. Wouldnt mind seeing it. :smile:
  13. I’m struggling to find any users of the Forge radiator apart from Jamie !
  15. DV8
    DV8
    Good effort with those diamond cut outs! Did you have to create any new brackets or anything to get it on there?
  16. Thanks! But I wouldn’t trust a muppet (me) to do this work. I have a Renault specialist that also works for race teams that does all the work on my car.
    DV8 likes this.
  17. Where about did you find this turbo water cooler from AS? can only see a clio kit on their website
  18. DV8
    DV8
    I think he has used the Clio one.
    James Thornborrow and DOOOOK like this.
  19. DV8
    DV8
    Wanted to follow up on this. Did a full day at Spa with ambient temps of around 26-31 degrees Centigrade.
    Maximum coolant temp I saw was around 105 degrees and that was in the afternoon after about 7 laps.
    Think spa is pretty kind to the coolant with plenty of places to bring the temps down.
    Def rating the Wagner though. Too kit!
    DOOOOK likes this.
  20. I used the Clio IV kit and had it modified to fit the Meg III.
    James Thornborrow likes this.
  21. Ahh I see, thanks for that, tempted to get one myself and make it fit, as my car is mainly track use.
