As the title says, I get a squeak at around 10mph. No input on the brakes, steering, clutch. Usually happens in 1st gear crawl on smooth(ish) roads. What could it be?
Anything, how we meant to help, when you have not said where its coming from, noises travel, and we can't hear it...
I actually can't tell. It's from outside because it's more pronounced when the driver side window's down. I'll try and stick a gopro outside and see where it's coming from.
It's while driving straight, no lock. GoPro caught it on a drive out so I'll upload the video and post a link once it's done.
Drives perfectly fine, and doesn't make any noises when I move the wheel side to side. Even if it was the pads making noises, they've got plenty of meat on them. I'll clean them at some point to eliminate causes, but i would've thought just braking really hard would do that. The video will be available on this link when it's uploaded
Yeah, What Ryan said. Sounds like the usual brake noises. They are terrible for it even with the OEM spec compound, May find its just built up grime and dust allowing the pad to stick slightly in the calliper
Ive never gone back to oem pads, used brembo oem spec, and trw oem spec pads, there no performance pad, but they do me for my driving, and theyve never squeeked once.
You were right, brake pads it was. Took the pads out and gave them and the discs a clean. Now nothing. It's all shiny. What kind of driving is yours? These are brembo OEM spec.
If standard pads, there made by ferodo, i bought brembos on make front and back, proper cheaper then renault, no squeeking.
