Squeak noise from clutch housing
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by steven938, Mar 21, 2021.
  1. Hello everyone
    I have a clio with the megane 225 engine and gearbox.
    Car works great apart from a noise that is bothering me.
    There is a squeaky noise coming from the clutch housing area, when I press and release the clutch pedal.
    Its the same noise when a fork pivot is not greased enough. Since the car has the hydraulic system and concentric slave cylinder, I believe that the noise comes from there.
    The slave cylinder is new. Have driven a few months with it. When the car is cold, the noise is not there but comes after 5 mins of driving. But when the car is at operating temperature, the noise goes away completely.
    Was thinking that maybe, the system was not bled correctly and that bleeding should be done through the slave cylinder itself.
    Would be great if anyone could help determine what is wrong with my car.
    Steven
