Spring Advice
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Liddell92, Jun 24, 2018.
  1. Hey,
    I have a Mk2 Trophy with standard suspension setup. I remember reading its 25mm lower as standard (and has cup suspension?).
    I'm looking for springs that will lower the car further, but will it compromise handling if i dont replace the standard shocks? Also, any good recommendations for springs that will lower it further than 25mm?
    Thanks,
    James
  2. Hello mate, if you're interested I've a set of Cooksport springs that should be coming off my car within the next couple of weeks hopefully. They've only been on the car for a few months, done less than 1000 miles. The ride is a little stiffer than standard, less body role and much improved handling. They lower the car by an advertised 25mm front/30mm rear, but actually are a bit lower than that, it's a much improved stance.
    If you're interested give me a shout, but I'll be advertising them and the r26 shocks as soon as they're off the car.
    Si
    Sent from my Pixel XL using Tapatalk
  3. Ps. It's an R26 they're coming off.
