Specialized Allez 16 2011 - Road bike in great condition
Discussion in 'Other For Sale' started by The Boosh!, Jun 22, 2014.
  1. The Boosh!
    The Boosh! RSM Admin
    I bought this bike in 2011 to commute to work, however I got a new job a year later and I haven't really used it since.
    Before I stopped using the bike, I took it for a full service and health check up, where it had both wheels realigned so they are 100% true, a new chain and the gearing retuned.
    I would estimate that this bike did around 1,000 miles in the year that I made use of it, and this is reflected in the condition of it.
    Here is the spec from Evans Cycles:
    Code:
    [/COLOR][RIGHT][COLOR=#222222][COLOR=#000000][FONT=Arial]Frame:[/FONT][/COLOR][/COLOR][/RIGHT]
    [COLOR=#222222]Specialized A1 Premium aluminium, fully manipulated tubing, smooth weld compact race design, integrated headset[/COLOR]
    [COLOR=#222222]Fork:Specialized FACT carbon, carbon legs, aluminium crown and steerer[/COLOR]
    [COLOR=#222222]Front Derailleur:Shimano 2300[/COLOR]
    [COLOR=#222222]Rear Derailleur:Shimano 2300[/COLOR]
    [COLOR=#222222]Number of Gears:16[/COLOR]
    [COLOR=#222222]Shifters:Shimano 2300 STI[/COLOR]
    [COLOR=#222222]Chainset:Shimano 2300[/COLOR]
    [COLOR=#222222]Chainrings:52 × 39T[/COLOR]
    [COLOR=#222222]Bottom Bracket:Cr-Mo axle, 68mm x 113mm[/COLOR]
    [COLOR=#222222]Cassette:Shimano HG-50, 8-speed, 13-26[/COLOR]
    [COLOR=#222222]Chain:KMC Z-51[/COLOR]
    [COLOR=#222222]Pedals:Black cage, body & toe clips with strap[/COLOR]
    [COLOR=#222222]Front Brake:Light dual pivot brake, Teflon pivots, forged alloy, with standard angle adjustable pads[/COLOR]
    [COLOR=#222222]Rear Brake:Light dual pivot brake, Teflon pivots, forged alloy, with standard angle adjustable pads[/COLOR]
    [COLOR=#222222]Brake Levers:Shimano 2300 STI[/COLOR]
    [COLOR=#222222]Handlebars:Specialized Elite, 6061 aluminium, 130 drop, 90 reach, 31.8mm[/COLOR]
    [COLOR=#222222]Stem:Alloy, CP bolt, 31.8mm[/COLOR]
    [COLOR=#222222]Headset:1 1/8" sealed Cr-Mo bearings integrated with headset, 20mm alloy cone spacer with 20mm of spacers[/COLOR]
    [COLOR=#222222]Grips:Specialized S-Wrap, with gel[/COLOR]
    [COLOR=#222222]Rims:Mavic CXP22[/COLOR]
    [COLOR=#222222]Front Hub:Forged aluminium, sealed bearing, Quick Release, 32 hole[/COLOR]
    [COLOR=#222222]Rear Hub:Forged aluminium, double-sealed, cassette, Quick Release, 32 hole[/COLOR]
    [COLOR=#222222]Spokes:Stainless 14g[/COLOR]
    [COLOR=#222222]Front Tyre:Specialized All Condition Sport, 700×23c, wire bead, 60TPI, with Flak Jacket protection[/COLOR]
    [COLOR=#222222]Rear Tyre:Specialized All Condition Sport, 700×23c, wire bead, 60TPI, with Flak Jacket protection[/COLOR]
    [COLOR=#222222]Tubes:Standard presta valve[/COLOR]
    [COLOR=#222222]Saddle:Body Geometry Riva Road, with steel rails[/COLOR]
    [COLOR=#222222]Seatpost:Specialized Sport, alloy, two-bolt clamp, 27.2mm[/COLOR]
    [COLOR=#222222]Seat Binder:Alloy, 31.8mm[/COLOR]
    [COLOR=#222222]Extra Features:Chain stay protector, chain catcher, derailleur hanger, clear coat[/COLOR]
    [COLOR=#222222]Weight:Approx. 21.94lbs (9.95kg) for the 58cm Size. (PLEASE NOTE: Weight is approximate and is provided by Evans Cycles as a guide only, actual weight may vary due to manufacturing processes and other factors)
    Here are some pictures of the bike:
    And here is the size of the bike:
    I am around 5 foot 11 to give you an idea of fit (and this is bob on for me).
    I will also include a bike cover I bought from Halfords in with the bike:
    Through the scheme I had the following added to the bike:
    Exustar Look KEO Pedals
    RX1 Set of Lights
    Borderman telescopic pump
    I would like £450 ono.
    Additionally I also have for sale a pair of Specialized BG Sport Road Shoes RSP. I've taken some pictures of them. They're in great condition as you'd expect covering such low mileage.
    £30 ono.
    I can deliver the bike to any services along the M1 between London and Sheffield, or anywhere around Dartford. Alternatively you can collect it from High Wycombe (HP13).
    Any questions let me know.
  2. £30 lol I'll have that
  3. Use to have an epic, awesome bikes
  4. Glws
  5. Might be an idea to list size of the shoes?
  6. The Boosh!
    Whoops apologies - I took a picture that illustrated that but failed to list it.
    They are size 10. I am usually a size 9 but was told to go a size bigger for cycling and these fit really well.
