225 Spark plugs and ignition coil 3
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Gprim225, Jan 13, 2017.
  1. Morning all,
    Need to change the spark plugs and the ignition coil 3 needs replacing as the wiring connection is damaged.
    Going to order the bits from renault parts direct. How easy are they to fit? Bearing in mind my knowledge of car mechanics is lower than most primates!
    I also need to sort the rear silencer exhaust mount and the upper engine tie bar also needs replacing.
    Hoping to sort these asap so I can get some Suspension, brakes and stage one done.
