265 Spark Plug torque (nm) setting
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Michiel, Jul 12, 2018.
  1. Hi All,
    Does someone on the forum knows what the spark plug torque setting (nm) is?
    Regards
    MC
  2. 250 is 28nm. Should be the same for 265, ( there is another value on the pdf manual which is 30nm).
  3. Make sure you clean around the coils before removing off the spark plugs, otherwise crap falls down into it and you need to suck it out
  4. Always do mine by hand, never had a problem
  5. I'm the same as Mikey - if you've done it before, you know it should just be very snug
