Selling my R26 gearbox as I’m fitting a standard ND0 with a gripper and different final drive. It’s in good condition and has no grinding or crunching into gears. I have many videos showing it is not grinding if these are of interest. I bought from a guy on this forum who had blown his engine at 67K since then I have covered no more than 3k in the last 3 years. Gear oil was still clean as you can see when I removed. I cleaned the gearbox before I fitted to my car and had nearly jet washed the label off, I tried to glue it back on but as you can see it’s now missing however I have added a photo so you can see the label was present and is 020 but also for peace of mind you can see the stamped NDO 020 on the bottom of the gearbox, you can also see the label serial number matches that on the stamped section A002661. The quick shift kit, slave and TDC sensor will not be included. Looking for £550 cash on collection Walsall or can take to Solihull Monday to Friday 8-6
