Sponsored By:
Some Nurburgring shots
Discussion in 'Track Days & Track Driving' started by r_turner01, Nov 9, 2022.
  1. Fairly new here just thought I'd share some Nurburgring shots of the car.
    Bit of a mixed feeling so far as had a fair few mechanical problems, wheel bearing failure, outer cv, and also more worrying had a track rod end nut fail... thankfully this was in the car park at 2km/h, lets not even think about what I was doing less than 20 mins before this!
    Over winter I am replacing track rods, drop links, shafts, and what ever else I can change to try and eliminate future failures.
    On the flip side, when the car was not trying to kill me it performed so well, in the dry I have AR-1s which just grip and grip, braking grip is quite something, and in the wet I put on PS4, very slippery out there but these did keep it in check most of the time!
    Next year I also plan to install a CAE shifter, the rest of the car is already a fully built DMSB/FIA spec car, full cage, KW Clubsport suspension, Pole position seats, and fully stripped inside.
    Anyhow, hope you like the pics courtest of racetracker.de including my favorite which was just going into the darkness, it was actually darker than the pic suggests, proper N24 vibes :smile:
    Richard
    NoneEvo, GT4Zed, DOOOOK and 2 others like this.
  2. Not much to say apart from epic
    r_turner01 likes this.
  3. Great photos. Wheel off the ground in the fourth one!!
  4. Nice photos.
    Covered up to much of that Liquid Yellow with stickers:grinning:
  5. You must be horrified to learn that black is paint
  6. Nooooooooooo
  7. If it helps, it is a proper race spec Megane
  8. MCM fan, nice!
