"Snap On Diag Fault" Connector Lower Dashboard Stearing Column
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Neil Mackay, Oct 5, 2018.
  1. Hi Guys, just ran a Snap On Solus Diag on the car, and came up with the following fault - "Connector: Lower Dashboard steering Column - Drivers door side behind cover, fuse box............any ideas? Basically cruise/speed limiter don't work at all and when the rocker switch is pressed in either direction the lights don't even illuminate on the dash board. As it relates to fuse box I can only assume its reading it as a Left hand drive car not right??? The horn etc works (which I think is on the same fuse so that's obviously ok.......Thanks
  2. Well thought I'd swap out the cruise control switch.....err as soon as I switched it on the switch fizzed and bellowed smoke....!!! Same part number so there's a serious wiring fault somewhere!!
  3. Squib faulty? Prob best off hooking it up to clip to read the faults, will give you a better idea.
