smell of Exhaust gas inside the car
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by stefansh, Jul 24, 2018.
  1. hey guys
    i have an issue with strong smell of exhaust gas in the cabin (megane rs 2013 with decat)
    even while the windows are closed and the AC works on circulation , every 2-3 days i have a soot accumulation on the front window ,dashboard and the Ac shutter,
    what can it be ?
  2. -Jamie-
    Leaking exhaust, downpipe studs most likely
  3. i changed all of the studs including downpipe,turbo,Exhaust manifold but nothing changed
    it maybe connected to the AC Pipes ?
  4. If you've checked the top of the decat pipe check the bottom too.
    Mine leaked badly from there so I fitted a new gasket and some copper nuts / bolts and it's not smelt since.
  5. hi, did you find the issue?
    I have the same thing
  6. autronix
    autronix RSM Club Member
    same thing here. I tracked down every potential issues , no visible traces.
    I have new turbo gaskets , new scorpion catback , all gaskets , bolts in order , no leaks found ....
    I suspect rear section final tube is dumping gas under the bumper.
    .... but on my other diesel meg the exhaust is just under the bumper and I have no issues.
  7. autronix
    this is the position of the exhaust. I might made a kind of basic backplate to block the gases entering under the bumper.
