Sloppy gear change, what bits?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by stupertsf1, Jun 15, 2015.
  1. Hi all
    Recently bought a Megane 225. The gear change is a little sloppy, knob does not centralise etc. The gearbox itself feels spot on though.
    I've heard its an easy fix, could someone please let me know what bits I need to make it like new again? I know K-Tec do a kit that includes their short shift but its quite expensive, I will look at using a different short shift further down the line.
  2. MBC
    MBC
    Springs gone?
  3. The White bush on the actuator swells over time, it needs honing out a little and it will be back to normal.
    Have a search it's been mentioned quite a bit, think the is a guide somewhere.
  4. Got it booked in for a check over on Saturday, so I will see if they can fix it.
    Thanks folks.
