Slight Oil Leak by sump.
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by charlie1984, Jun 18, 2016.
  1. hi chaps,
    just wanted to know if any of you guys have ever had a slight oil leak by the sump... it isn't a major one but my mechanic can't see exactly were its coming from without spending a little more time on it so just wanted to see if anyone might know anything.
    cheers
    c.
  2. MBC
    MBC
    As in a slight drip?
  3. matt e
    could be the the crank seal
  4. mines been slightly leaking for 2 years, minimal amount, mark @ MRS says it's common ...
    always has a wet bit on the plastic under tray ....
    MBC likes this.
  5. Mine was like that when I done my mounts etc. One of my ST170's done it too. As said, common minor problem with any car
