Slight misfire under load
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Sammy_2007, Dec 25, 2013.
  1. Hi guys I'm getting a slight misfire for a second or so under load. When u put your foot to the floor it pull to 5psi has a slight misfire then continues to pull all the way through any ideas?
  2. Crappy injectors mine is the same has a lumpy idle aswell
  3. As said injectors or possible sign early fuel pump failure?
  4. Injectors or a fuel pump. I could clip test it for you.
  5. Injectors wise I only had them fitted at the start on December at rs tuning so would u start with new fuel pump? What about coil pack could it be a pos?
  6. Get it on a scanner is your best bet chap. It's one of those faults that as a tech you need to feel in person!
  7. Ok cool if you could have a look at it lemon that would be fantastic when ever your free
  8. Sam was it you who text me about the turbo problem.
  9. Yup was the map in the end so that's all sorted now. just this small problem to fix :-)
