Single mass flywheel indentification
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Carl mcintosh, Sep 6, 2018.
  1. B06D81FD-6FB5-46F9-943E-2BA32D8A8088.jpeg Hi there
    Can someone please help me identify this please it’s a solid flywheel but unsure if it’s any good the brand and also if it is reusable what clutch will mate up too it.
    Found when removing old engine and slit gearbox.
    I’m hoping I can use it again!
    TIA carl
  2. ianplymouth
    I am sure there were only a couple of different manufactures for the single mass flywheels, but could be wrong.
    It looks in okay condition so would be okay to use again.
    If there was a standard looking plate in there, you will be able to use a standard plate, an R26r plate or a diesel one.
  3. A1939BB1-D7D9-451A-BD55-901A5D4BD265.jpeg I am hoping to go r26r with it. Just unsure if the brand. It’s in good nick just needs a clean by hand.
    Here the clutch.
  4. ianplymouth
    yehh that's a normal clutch plate so a diesel one or the R26r one will work.
    Its the cover plate that also that needs to be a diesel one, it has a higher clamping force.
  5. ianplymouth
    or you could go to your local car parts supplier and get a Diesel clutch for around £100
