250 Single mass? dual mass?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by EBA66, Jul 5, 2019.
SMF or DMF
  1. SMF
  2. DMF
Results are only viewable after voting.
  1. Gents, I'm planning a big service on the car that includes forge-ing the engine. The question is: since I am changing the clutch should I go for a SMF? I've heard so many horror stories with SMF ... and I want to hear more oppinions! Is it worth the change performance wise? If it's just vibrations as cons, I could live with, if it's damaging gearbox in time... not!
  2. Sounds like your car is broken with a SMF. If a shop is recommending one, they are absolutely clueless!
  3. If it just sounds, it is not a problem! :grimacing:
  4. Bump!
    Really no mk3's with smf on this forum?
  5. The SMF is nothing to do with damage to gearbox but more smoothness of engine as a DMF will absorb vibration and smooth interaction with clutch when you release the pedal, saying if a flywheel is well balance and of appropriate mass for the engine coupled with a dampened clutch disc then it should be ok
  6. Aren't all clutches dampened?
  7. no, if you have a DMF the the dmf has springs in them to dampen vibration and smooth your clutch
