Sorry if this has been covered a million times, I have used the search function to try and find it before I posted this to no avail. One of my sidelights has went out, had a quick try to access it through the removable panel in the wheel arch, but couldn't contort my hand and arm to get in properly. Is there a special technique to this or am I best removing the wheel to get? Also which LED bulb option is best for them, I think I already have some 501 fitting LED's somewhere in my box of spares. Cheers, Dan
I did both of mine from under the bonnet but it's not easy. Luckily I have relatively small hands so I was ok...
I always found taking the wheel off was the easiest way, gives you a bit more reach through the wheel arch
