265 Shaft spacer
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Paul ja, May 26, 2019.
  1. Does anyone have stock of the 8mm shaft spacer or is it a case of getting one made ?
  2. KTEC sell them.
  3. Ah ok, can't see it on their web shop. I'll ring them tomorrow
  4. They are on eBay.
  5. Found them - thanks
    Ktec selling them in 2's - I've only seen postings suggesting fitting one to the passenenger side (short shaft)
  6. Sell one.
  7. Ordered - thanks
  8. What do the 8mm spacers do.
  9. Prevent the shaft (predominantly passenger side) popping out when running a lowered car
    From what I've read it all depends how low and how much negative camber you run (on adjustable top mounts)
  10. Oh right, do you want to sell me the other one then if you only need one
  11. Have to see when it's all fitted / set up / proven
