Noticed today driving that both the service light and the airbag light come on at the same time but dont stay on, only comes on occasionally. Anybody ever had the same issue before? Cheers. Paul.
IIRC, if you have seat airbags... The electrical connection is underneath the seat... With the seat moving backwards and forwards to access the rear seats, the connector can work loose. Setting off the airbag light. Worth checking! Sent from my iPhone using Tapatalk
Have you got a scratching type noise when you turn the steering wheel? The squib/ clock spring/ rotary coupler is a common fault on these cars and may be that.
Not that I know of mate. Hasn't come back on since so god knows what it was. Checked the connector under the seat and all is fine there. If it comes up again I'll get it looked at because I have no idea what it is you've mentioned or where it is lol. Thanks anyway
