Sensors Nightmare!!
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Dan225RS, Apr 25, 2015.
  1. So had the car in on the diagnostics port. Came up with 12 sensors at fault. Surely this cannot be right and must be something bigger thats causing all this flashing up?? Sensors that came up as fault are as follows.
    DF194, 093, 092, 026, 102, 378, 071, 072, 091, 210, 193. Any tech guru help would be much appreciatwd?
  2. Anyone have any advice on this. Car has been into 2 garages and nobody has any idea. Car is really quite dangerous now and feel like im throwing money at it for no reason. Help Needed???
  3. Usually when you got loads of error codes, depending on what they are and if they are isolated to one area (eg comfort and convenience or just fuel management or just ABS) it suggests a module failure which could be due to water ingress.
    Best option is to reset and go drive the car then rescan. You don't know how old some of those codes are and could be harmless. For example sometimes you can trigger a crank position sensor fail by stalling the car.
    What made you scan it?
  4. check the fusebox under the battery, i bet it's wet.
  5. Im going to try that today, see if that sorts it out cheers guys. Feel like im throwing money at a bottomless pit at the moment.
  6. #standard
