Hi Have a 175dci RS with standard leather seats The seating position is too high, even at the lowest setting. What options are there to a. Lower the seat further b. Try to remove the seat frame ( seems integral) c. swap the seats for alternatives (which ones fit) which sit lower on a different frame Does anyone have any experience in this area Thanks.
If you want a lower driving position you will have to fit after market seats, there isn't any real way with the standard seats. You have lowered it as much as you can with lever on the right hand side.
Frames will either have to be Ktec or the was/is someone on here i think its VBR and then side mounts and whatever seats take your fancy
