Hi, Fitted the new Scan Gauge today (looks great in the pocket under the radio). My question is (to those who have one fitted) is, how long does yours stay on after you've turned the car off and locked it? I was a little worried at first as mine stays on for around 10 mins! I have been starting the car, then turning it off to check and it always seems to be 10 mins. Is this normal? Also, what displays are best to have showing? I have - Revs fIA (which I believe is intake air temp) Volts fWT (water temp?) Thanks, Dan
Not sure when mine turns off but probably between 5-10 mins I have... Intake temp coolant boost torque
