Rs275 trophy decal positioning
Discussion in 'Exterior & Bodywork' started by ShaneBe, Mar 13, 2021.
  1. I'm French and had not sure If I can make sense ;-)
    Look at the pictures from the link you send and tell me if that help you.
    Aile = Rear wing
    Flèche haut: 35mm, sachant que le haut de la bande est posé à 5mm du pli de l'aile (face au becquet).
    Top arrow show that the stripes are 5mm from the top of the wing gap and 35mm from the corner of the window.
    Flèche bas :150mm
    Bottom arrow show a 150mm gap between wheel arch extension and side of the stripe.
    Portière = Door
    Flèche haut: 60mm Top arrow shows 60mm gap between door gap and edge of sticker
    Flèche bas : 55mm Bottom arrow shows 55mm between door trim and edge of sticker
    Hope this help.
    Sam Havenhand likes this.
  2. Perfect thank you!
