Within the next few weeks I will have this setup for sale. Bought the dampers from a lad on here around 8 months ago with 15k miles on them. He was converting to Ohlins. I've added another 6k on to that since then so they are in great condition. They come with h&r springs that were fitted at the same time as the dampers. They will be connected to the fronts already so no messing needed fitting them. Not looking to split so will come as a set. I bought them as my front damper broke at 65k miles. I'm now converting to coilovers. Looking for £300 ono Cheers
Alright jack I'll take the springs if you decide to split! Thanks for run out before! What else you done to that car? The handling was immense!
If I decide to split them they are yours. I've got a powerflex handling pack as well as the springs. And I've changed every single link/bearing/bush on the front
Like Jamie said, they are slightly tweaked. They feel that little bit better than the standard ones. Not a huge difference but feel more compliant and better controlled
Sound Mikey. A few people have asked about the springs so there is a chance I will if you want the dampers
Finally got round to fitting the new suspension so this is all up for grabs including top mounts which are less than a year old. Ideally would want to sell the full setup so not messing about taking it all apart and selling in bits and bats. Original price was £300 but that was without top mounts so £350 posted for the lot. Cheers
