Came off this morning when I tried to pull a bit too hard - door was stuck in the mud. We are taling about the black handle on the inside here. Any suggestions as to where I could purchase a replacement from? Tony
Try ringing some Renault part suppliers/stockists, RPD have sourced and supplied items I couldn't find elsewhere.
assume this is the same? part code in description for you to check https://www.ebay.co.uk/itm/Renault-...532756&hash=item23b4a4f160:g:kQ0AAOSwVaZa4ISY
oh my apologies! you've done a proper job there haven't you haha. As an above comment, RPD should be your best bet. sorry for being useless lol
I haven’t rang Renault yet, but checked all over google and RPD, no luck! Mine looks like it has smashed in the same place as yours - I was going to try some bigger washers and refitting the broken one for now. Hopefully sorts it
There is no point duplicating our efforts - why don't we work together to sort it out instead. I am a french speaker - will troll the french forums for info. Can you perhaps meanwhile contact Renault UK for advice? Thanks
This has become a common issue down here in Aus, there's a few threads on ozrenaultsport.com covering DIY repairs. I decided on a preemptive solution for mine;
You can't buy just the handle you have to purchase the complete door card from renault 400 pounds approximately I did a repair on mine purchased a door card from a non rs with the same handle removed it and then with washers and new bolts and nyloc nuts fitted it better then renault did in the first place .
