250 RS250 sport chassis.. Rear rotor conversion
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by soulblade, Oct 19, 2014.
  1. Hi all,
    Is it possible to replace the rear solid rotor with a slotted one from cup version?
    I believe both callipers are TRW made but the rotor on cup is a little bit bigger?
  2. On the mk3 the brakes and discs are all the same size, the only difference is the grooves. No size difference whether it's a cup or not.
  3. As above, straight swap although the grooved discs are slightly more expensive.
