RS250 Direct Replacement speakers
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by paulashy, Nov 19, 2014.
  1. Looking to replace my OEM speakers but don't want to have to do any changes in the wiring or anything like that just bolt a new set in no drilling. What speakers are direct replacements for both the front and rear. I'm under the impression spacers have to be used due to the way the OEM speakers are made which is fine just read a few thread now which go on about re-wiring and drilling new holes for most aftermarket speakers is this the case?
  2. The standard are riveted in so need drilling, spacers are required, but dont know if this case with direct fit ones, if you get universal speakers with spacers, you can get plug adapter which converts the plug to spade connectors, these are know as dacia duster speaker adapters as they only list the old ones on ebay.
  3. Ah right cheers didnt realize they were riveted in dont mind drilling them out just dont want to take the door card off to find alot of modifying needs doing just to fit some speakers ill just put up with the OEM .
  4. Any speakers with additional converters/adapters.
