250 Rs monitor
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by seany250, Feb 16, 2016.
  1. Hey guys I have a Megane 250 and I am trying to see if I can retrofit a rs monitor into it. Has anybody done it or know what I need to do to install it into the car. I've seen on other cars Clio etc you need to get a screen and activate the programme through the clip diagnostic computer. If anybody could shed some light on this if be very very grateful. Thanks sean
  2. Rimstock
    Rimstock Banned
    My car is missing it's RS monitor and I e been looking for a replacement for 4 months so good luck finding one lol
  3. I have a PCI3 Data Monitor
    Gives;
    Boost pressure (BAR or PSI)
    Intake air temperature (degrees C)
    Coolant temperature (degrees C)
    Engine speed (RPM)
    Battery volts
    Throttle position %
    Road speed (mph or km/h)
    Ingnition advance (degrees BTDC)
    Air flow meter (g/s)
    Lambda sensor (Lambda ratio or AFR)
    Knock correction (degrees ingnition offset)
    Injector duration (milliseconds)
    Exhaust gas temperature (additional sensor needed)
    Time of day clock
    Oil temperature (additional sensor needed)
    Oil pressure (additional sensor needed)
    Plug & Play via OBD port, what more you want? much easier.
    Used one as shown here since my Impreza days years back
  4. That cabin a blast from the past
    The old defi gauges
