RS Monitor - Throttle Mapping
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by NotaDiesel!!!, Dec 18, 2018.
  1. Obviously I know about the sport button.
    But I am sure I saw elsewhere where was a screen in RS Monitor to adjust throttle settings.
    Is this so?
    How do you find it?
    Found loads of Graphs/Oil Temp/G Meter etc.
  2. Once switched monitor on, use the left button and click twice.
    First one takes you to the shift pattern or something then the second takes you to throttle map. Adjust the scroll wheel up and down to adjust.
    This is on V1. You may be V2.
  3. I have a little joystick thing & touch screen.
    I gues since mine is last of the last it must be on V2.
    Does it change it much?
    Trying to make exhaust make more noise rather than change mapping. As I guess you get used to what you have.
  4. It changes the throttle map :tongueout:. I leave mine set to sport
  5. Have you tried the center box delete yet?
  6. Is there a best setting for the throttle maps, extreme seems the quickest but maybe its just a placebo affect.
  7. -Jamie-
    Linear if you want a pedal that is actually a pedal for modulation. All the others are a waste of time
  8. On v1 sport mode needs to be activated before altering map settings. And jamies right linear is defo most controllable although after nearly 2 years i can drive smoothly in sport. Put it in extreme mode and it's like skippy the bush kangaroo is driving
