As above guys I have searched but cannot find anything so here it goes... Can the xenon headlamps be fitted to my 250 with cup headlights? Yes they are a bit heavier but I'm also a bit snobbish haha any idea on the cost of xenon headlamps? Cheers Matt
I have done it, the self levelling system no longer works though so need changing back come mot time. I had to splice into the existing wiring. I brought them from a member on here for £400, make sure you get the black insert ones they look so much better
OK so some wiring does have to be done? Can the self levers be made to work? Lucky I have a mate who an auto electrician haha
No wiring just splicing into existing loom, im not sure on the self leveller ,You're mate should sort you out.
i had hids in my old car and it passed three mot's with them as all the bits were totally hidden and the mot tester cannot remove things to check and must give you the benefit of the doubght
