Hi, Recently bought my megane 250. It had a Xenon conversion retrofitted, it has capacitors fitted. It also has auto lights. I am getting the passenger light randomly shut off (restarting car fixes it) with the drivers side light flickering, obviously not a good look. I have taken the lights out, both have capacitors in them, and i have shaken them (as I thought it occured over bumps) and nothing happened, both were fine. Do you guys have any other suggestions on what to check? I noticed the lights only have 2 out of 3 connectors plugged in (my guess was the auto level sensors not there as not factory fitted)? If I turn the car on and off both lights work again, making me think its not bulb related. Many Thanks Tom
Check the ballasts. I had a cheap eBay ballast and it had the same symptoms as yours, I then swapped it for one BMW / Mini one and it cured it
really? How would I know if they're faulty? Also, I don't suppose you know the part number you swapped for? Thanks
