replacing front speakers
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by denbers, Oct 25, 2013.
  1. passenger speaker has gone, how easy are they to replace as im guessing its door card off? also what is the size?
    cheers
  2. Will.
    They need to be shallow fit because of the spacing. Can't cut the area behind the speaker either, otherwise water will drip onto the speaker. Not a good design from Renault.
  3. R26
    R26
    It's not door card off, pull the covers off carefully. Speaker size is 13cm, pioneer do a direct fit replacement.
  4. I cut mine feck it!!!!!
  5. My passenger speaker has also gone. Is this a common problem?
  6. Stu
    Stu
    I fitted the direct replacement Pioneers, much better than standard. IMO the head unit needs to be changed too to take advantage of the new speakers, didn't notice any difference with the standard head unit.
  7. Oe stereo is sh!t burn it!!!!
  8. spot on ill give them a look see and get it sorted, thanks for the info :smile:
