225 Replace Meg 225 recirc valve
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by maece82, Jun 13, 2019.
  1. How good or most likely bad is the accessability to replace a most likely broken OEM recirc valve on the OEM Meg 225 turbo?
    Is there any OEM recirc valve available or only the "closed" Forge one? Any silent!!! alternatives available?
    Many thanks
    Marcel
    Is this the recirc valve, right?
  2. matt e
  3. ianplymouth
    It's very tight down there, especially the bottom one, although you don't have to remove it fully.
    The choice is either the Forge one or there is a Properfect one.
    Best to undo the top and bottom stay bars, so you can tilt the engine a bit to get in there.
  4. I have an original one if you need one that I removed to add a properfect one. Fully working and diaphragm looks great. Original one is quieter than properfect or forge. £15 posted. Can email a pic.
