Renault grooved front brake discs
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by andya, Jun 30, 2015.
  1. With grooves on the discs should these be handed left and right to fit on car so that grooves both run through the callipers the same way.
    cheers
    Andy
  2. The r26r ones both face the same way so the grooves are different on on each side iirc.
  3. so they are not handed , seems strange if you ask me
  4. Cheaper is what it is.
  5. Every set of grooved discs I've had are always handed so you can put them forward or backwards so both face same way
    but I'm not going to get into the which way is right as many people have different theory on how they should go
