Renault Clip issue
Discussion in 'Megane Discussion' started by mrpink, Mar 22, 2015.
  1. Hi Guys,
    I have a non original Renault Clip which had been working fine, and then one day when launching the software it said it had an error along the lines of detecting a wireless probe.
    I left it for a while, and then formatted the laptop and re-installed the software and it worked again.
    I have come to use it and again it launches and gets to an error along the lines of a wireless probe.
    Has anyone come across this before?
    If so what was the solution?
    And what causes it?
    Thanks!
  2. What version of clip do you have. Can you post a screenshot of of the error.
  3. Ill grab the info tomorrow and get back to you :smile:
  4. Latest software looks for the wireless obd connector. Have you tried plugging the lead in car with ignition on them running software?
  5. Give it a blast today.
    I'm on quite old software (v103) but worked fine. Ill just have to suck it and see and update if it happens again (not that I use it that often).
    Cheers for your help :smile:
  6. Gavin.
    Gavin. RSM Admin
    That is old! i'm on v145
  7. I've just downloaded 145, but a bit dubious about installing it while this is working! Is there much difference?
  8. Gavin.
    Gavin. RSM Admin
    There must be, it looks a lot more polished on v145 that the older versions. Not sure what the differences are though, i'd image new software elements for new additions and new cars etc. It'll all be under the hood stuff.
