What is it the clip tool does? I've normal OBD reader for fault code reading, clearing, monitoring etc. Does this have any worthwhile features that might be of use.
Its the renault specific one and would tell you exactly where an issue is for example - it can be used to turn off airbag warning lights etc without the need for resistors etc. I only have torque pro - but my RS garage in Edinburgh have used CLIP when I removed the airbags and std seats.
This is the exact one I bought, still going strong 18 months later: http://www.aliexpress.com/item/2014...tic-interface-Renault-Can-Clip/596683759.html Just in case you aren't aware it needs Windows XP to run, I have a virtual machine running on my Mac and it works fine.
Did it come with the obd2 lead? How long did it take to come? Maybe order one myself mate thanks for the link
Yeah it comes with everything you need mate, bar the actual laptop. It does come from China so it was 2-4 weeks ish.
Use a bit of common sense with these copies though, don't go trying to reprogram the ecu or anything daft, it will end in tears!
