Renault Can Clip - Traction control / ESP
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Gavin., Mar 26, 2015.
  1. Gavin.
    Gavin. RSM Admin
    I remember someone saying to me it can be disabled with the clip, or maybe you can change the speed that it reactivates form 30mph to whatever you want? Anyone know if it is possible and if so how you do it?
  2. Not that I know of, but there is a wiring mod that can be done to install a switch, I think there are details on meganesport.net
    Sent from my GT-I9100 using Tapatalk 2
  3. Naith
    I've done this and it's not recommended. It kills a lot of other features on the car too.
    Just get it sorted via clio. As soon as you find out how to gavin will you run it on mine please as I don't wanna use the switch setup.
  4. Pretty sure you can do with fastchips RStuner box and an additional module too
  5. Paul at RS Tuning done mine when I was having my injectors and remap done
    I think it's set to re-engage at 180mph or something silly like that.
    So you must be able to do it their an RSTuner box like jjones82 has said
  6. Yep jjones is spot on, it can be done with my fastchips tuner and the relevant modules......
    http://www.fastchip.nl/index.php?pa...ategory_id=45&option=com_virtuemart&Itemid=26
    Module features:
    • Read and clears all pending/stored EPS fault codes.
    • Choose desired steering force strategy, weak--strong. (*)
    • Read and clears all pending/stored ABS ECU fault codes.
    • ESP /ASR automatic reactivation treshold (*)
    • ABS Hydraulic unit and Brake circuits bleeding.
    • ABS Pump motor test.
  7. Gavin.
    Gavin. RSM Admin
    There must be a way, I just don't really want to go messing around in the program functions on a clip copy.
  8. It can be done with Clip. I should be able to do it for you if you want or you should wait until next week when I get my car back from Mark Black and I do it on my car to have a clear answer.
    S.
  9. Gavin.
    Gavin. RSM Admin
    I have the clip already, just some instructions on how to do it would be great :wink:
  10. Gavin.
    Gavin. RSM Admin
    I'm lost on this, I can't find any value to even attempt to change.
  11. Any update on this. My traction control is killing me on track kicking in at 30.
    Its making the car more unstable to drive
  12. Interested only to learn more about Clip!
  13. Gavin.
    Gavin. RSM Admin
    I never figured it out on mine, wish I had.
  14. It was the bottom one on your pic Gav
    Looks like yours was already set to stay off until 255kph, which is right for Cup/R26 and 175 (i think).
  15. Gavin.
    Gavin. RSM Admin
    Well it came back on over 30 so it made sod all difference.
    I didn't change that either, it was already set like that.
  16. Hmm that's weird then.
  17. Here's how my Cup looks - I doubt it's the configurations on this screen that need to change.
