Is it possible to remove the grills in both bumpers without taking the bumper off I want to get them sprayed in Matt black Cheers
In the front it is possible to remove the upper ones without removing the bumper. It's very fiddle tho and need to be careful you don't snap the small clips. Tbh may be easier to just spend 10 mins removing the bumper. the lower one is not possible tho. It is fixed in with metal rings and is wedged between the under tray. The under tray will need to be removed to take the grill out too which you have to drill the rivots. not sure about the rears tho
Does that auto finesse revitalise trim restorer not turn them black. Maybe easier to see if soem one can do them while there still fixed coz they are very tricky to remove
The frt bumper is coming off on wed anyway mate so should be easy enough to get out I only asked if poss without taking it off as wanted a job to do Sunday Cheers
