Can this be done without removing the subframe? i can't see how I can get the bolt out as the subframe is in the way
You need to undo that pissy little frame that supports the rad etc, you maybe able to get away with pulling it away or down etc
I ratchet strap the rad pack to the slam panel & remove the front subframe. It's the only way & it has to be removed to get to the lower arm bolt. Lee
