Removing linkage
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by MJAbela, Dec 1, 2015.
  1. Any tips for getting the linkage out the box on a 225? All bolts undone, cables unclipped, just doesn't seem to pull out of the box. Cheers
  2. Daz
    If you've got the correct 4 bolts out it should just wiggle off - give it a tap if it's not been off before.
  3. There's a locking nut on the side of the gearbox. Have you taken that off?
  4. As above don't forget the locking nut.
