Before I start yanking and break clips and God knows what else, how easy are these to remove? Can I do it just from the door external side or do I need to remove the door panel ?
If you open your door you will find a rubber grommit at the same level as your door moulding remove grommit and undo screw then the mounlding will slide one way or the other, remove the moulding from the door and then you can remove the part in question rich
