Hi all, What do you guys recommend for removing dead insects, rabbit blood, entrails etc that won't cause any damage? Thanks Keiron
G101 APC autosmart, no rubbing required, just dissolves them, spray on rinse off. And it's wax safe. 5L for £15
All these products are crap and no better than a hose pipe, just a waste of money. Best thing I've ever used is the sponge with the netting round it, their brilliant
Best thing to do is try and soften them as much as possable. I'll soak a microfiber in water and lie over the areas while i do the wheels. Then when you come to do your choice of wash method they just full off.
If the bugs have dried out and are caked on spray some WD40 on them and leave for a minute or two then just rinse off. I'm referring to bugs on the bodywork, obviously not a good idea to be spraying WD40 on your windscreen.
I use to use g101 until some 1 in work didnt water it down enough and it wrecked the decals on my f1 , it also strips wax off , make sure its well watered down
