Removing battery. Help!
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by RMS225, Apr 14, 2014.
  1. Hi all.
    I want ant to remove the battery on
    My 225 to fit large intake pipe. But I've read stories
    of cars throwing up fault codes and issues.
    What's the story?
    Just ts remove and refit?
  2. Aye just remove and re fit. Reset windows after bt holding the switch up for about 15 secs.
  3. Awesome. Thanks bud.
  4. I had to reset steering as well when I took mine out last by going slowly from lock to lock
  5. Ahhhh that's the kind of stuff I need to know thanks bud.
  6. And don't forget about your radio code if you still have the original radio
  7. Always happy to help
  8. Where can you get the radio code from as my car didnt come with it?
  9. pull the radio out, sometimes it's written on the radio body.
  10. People on here can get you the code if you can't find it you need to take your radio out and give them a code of the side of it
  11. My radio code is on a little sticker inside the cover of the service book.
