R26 Removing air conditioning / climate control Megane R26
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by dodottiR26, Feb 17, 2016.
  1. Hello friends, after emptying the machine, removed all seats, stereo and speakers, in short, everything you do not need to have fun. I thought now to remove the air conditioner, there is someone who has already done it? It's worth? How much weight you gain?
  2. the pump weighs quite a lot, i took the guts out of the inside and used the casing with the pulley to use as an idler, it's a lot cheaper than the alternative :smiley:
  3. compliments!!! How much weight do you save?
  4. Must be a kilo or 2
    The parts inside are quite heavy and it's full of oil
  5. Ok:smiley:
  6. I did put the back part of the casing back on, because it weighs next to nothing and it has another fixing on the rear end.
  7. lol
    Is it in the 6 or 7 Kg range, or more like the 2 to 3Kg range?
  8. The glovebox weighs around 3kg lol
  9. I am not sure Papps, all i knew is i didn't want it on there, i still have the internals so i might weigh it to see :smiley:
    I need the glovebox so that is staying, i wont have anywhere to put my sweets if i take it out
  10. Is this a road or track car?
  11. Both :cool:
    But it is not my daily drive
  12. How do you think the price for courting the aircorn system would be?
  13. matt e
    what do you mean by courting?
  14. But what is the need for you to remove the entire air conditioning system from the car? If you want to gain weight, I think you only need to take out part of the air conditioning system. You can take the air-cooling part out of the car, not the other parts. Or you can resort to an even more ingenious idea, you can look for some pieces that are easier. Like, I bought it off https://www.socool.sg/pricing/. you will also gain weight, but you will also have comfort when driving the car. Which is quite important to you.
  15. I was at the Ring a couple of years ago and it was super hot. The number of guys who were dying inside their track cars which had had the AC removed was hilarious. Given most TDs are in the summer and driving there/back is likely to be hot/warm i do think AC is worth keeping.
    Brigsy likes this.
  16. I debated removing it on my track only 250, did a track day when the AC wasnt working lol went and had a new AC radiator thing and had it re-gassed and it's staying put. It's not fun being cooked alive with polycarb windows
