Remap interior electronics
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Lacko, May 29, 2014.
  1. Just curious how easy it would be to access modifying the code for interior electronics such as fan controls etc on a r26? I have a bit of electronic knowledge behind me and the whole auto button issue where to turn off auto you have to change all the settings really annoys me!
    Is there a bit of software and a access point or am I just talking a load of old tosh??
    Tom
  2. I would imagine it would be defined code burned into an EEPROM, I certainly haven't come across anything through clip
    If u could trace the chip that controls the fans I'm sure it could be read back and changed unless it's locked down code
  3. I am not sure I understand the issue here ? Auto is on , therefore if needed the A/C will kick in.
    Press up or down once to disable the auto - have I missed something ?
  4. MicKPM
    MicKPM RSM Trader RSM Trader
    As above you cannot alter this as it's a pre-programmed function in the HVAC control module.
    Trying to change it would be like reconfiguring the reaction time in your ABS module from detecting a wheel locking up and reacting to it.
