Recommended Oil for F1 230 R26
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by MPG MAN, Dec 19, 2016.
  1. Can anyone recommend good oil to use if I need to top up? I am not losing any oil at oil and my oil is not due to be changed for another 9k miles but I'd like to have some just in case.
  2. I would just buy any RN0710 (or whatever Renault spec it should be) fully synthetic oil. I bought Shell Helix Ultra for less than £20 per 5l recently but whichever is on offer would do.
  3. Can't you find out what was added last time it was serviced? I didn't know what to get for my R26. Used Shell Helix Ultra, Millers etc. in other cars but in the end went for the Renault Elf Evolution 5W40 stuff from RenaultPartsDirect due to quite a few recommendations on here. Just need to get some Fluorine grease now so that I can change my spark plugs.
  4. Elf Evolution 900 sxr 5w40 is what I use but it can be any brand as long as its (ACEA A3/B4)
  5. Are all ACEA A3/B4 oils also RN0710 compliant ?
  6. Standard Renault spec Elf stuff in mine - Nothing wrong with it
  7. Fuchs Titan SuperSyn... Opie oils, there's a discount code on the "other site"...
