Ok, I give up searching, where can I get a replacement wheel bearing for a R26r? I assume it's the same as R26 and has the 30mm diameter Rear discs are OK condition so would rather spend £50 on a bearing than £250 on a set of discs! The 25mm bearings are easy to source but can't find a single 30mm version available online. I'm new to searching for Renault parts though so almost certainly missed some specialists...
The bearings should.... should... have a part number on them somewhere, it will be hidden behind the nut. Give that number to a bearing supplier and they should be able to get a pair Sent from my SM-G930F using Tapatalk
Great idea to check the stamp on the current bearing It's def 30mm If it needs 10 tonnes to push out though I could be in trouble, only have a bench type press!
So it's marked SNR FC 40696 S12. The other marking is 13364/23. This number doesn't look unique to just one bearing in the SNR catalogue - but the 2 which are the correct size are either R155.122 or R155.113 kits Have sent some messages to uk SNR suppliers so let's see if they can help and supply...
Dude I have a spare rear drilled disc from a r26 in great condition if that helps . . . I'd take £50 plus postage for it . . .
Tapered roller bearings FC40696S12 Bearing number : FC40696S12 Size (mm) : 30x62x48 Brand : SNR Bore Diameter (mm) : 30 Outer Diameter (mm) : 62 Width (mm) : 48 Not sure if this helps but if you search on Ebay for FC40696S12 a few come up for around £20 each!
Thanks for the eBay bearing idea - will have a look Is that price for plain discs or R26r grooved? Will have a look!
I bought the 25mm and tried fitting them today a d didn't fit, I'm gonna have to try the 30mm ones next, the strange thing is I only have a 225 5 door not a r26
