Hi guys, My 250 rear tail light does not work on the drivers side. strange thing is they are dual filament and the brake light works, so it must be getting power ? Does anybody know where the fuse is located or had a similar problem. No idea what it could be. The reg plate lights are also out if that helps, which makes me think it''s the fuse. Thanks Matt
Sounds like a failed bulb. Switch it with the opposite sides bulb to check power. Sent from my iPhone using Tapatalk
Hi mate, did you get this sorted? It's just happened to me on mine and I've got no idea why! Sent from my iPhone using Tapatalk
