So the missus got flashed by a car today on way home. Pulled over and apparently when she indicates right all rear lights flash. I’ve checked and it does. Is it an obvious fix? Cheers
Tell her she'll have to keep going left to reach her destination [emoji6] or do what many drivers seem to do nowadays, just don't bother indicating [emoji35][emoji35] Sent from my SM-G955F using Tapatalk
I’d agree with this. My other car used to do it. I used to have to let off the brakes so my indicator would come back on ha ha. The contacts were damp and corroded.
Slight bump but has anyone got a proper fix for this, mine have been playing up for months with no amount of cleaning earths or unplugging and plugging back in helping....
Battery is under the bonnet on the R26. I’ve clean up both earths that are on either side of the boot behind the carpet still no change, N/S indicator and brake flash alternate
Take a wire direct from the battery -ve to the -ve on the light, to see if that sorts it, if it does then you have an earth fault, if it don't fix it its something else
