Rear discs
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by 3 crispies, Apr 4, 2015.
  1. Stripped calipers and pads off, discs are grooved and have done same to pads. How simple to replace discs only and reuse bearing and abs ring or is it not worth the effort. :tongueout:
    How do rear discs come off anyway. :rolleyes:
  2. Not worth the effort mate. New discs come with new bearings and abs rings.
  3. As stevo says really not worth the effor mate, and you will more or less damage the abs ring, new discs mate and they come with the bearing and ring on them and they are a simple job to do
  4. How do you remove discs in simple terms pls, cheapest I can find are brembo £220 on flea bay. KNOW ANY OTHERS CHEAPER.
    Also my rewind tool didn't fit very well are they a special size thought all standard size.:tongueout:
  5. Undo the bolts to remove the caliper then just remove the hub nut and take the disc off, surely ads on here does the discs cheaper, g172 over on cliosport does a good price on rear discs
  6. I paid £178 for discs n pads delivered off ads on here
